oil leak location
Old Dec 18, 2019 | 08:38 AM
joycie01's Avatar
Default oil leak location
newbie here. 2009 ford escape v6 2wd 160k. oil seems to be leaking all around the oil pan. block is oily above the pan; was wondering if there are 'typical' or 'problematic' locations for this malady? any and all help appreciated.
Old Dec 18, 2019 | 03:47 PM
Once everything is covered with oil it becomes difficult to pin point unless you can see it running out.
What is usually done is the area is cleaned and then watched for where the oil is exiting. There are so many possible places and believe it or not they are many.
A leak can be higher up than where it seems to be coming from. Sometimes the fan can blow the oil to where it seems like the location, and it can fool you.
jcasaccio
Oct 7, 2018 08:02 AM
blubing
Jun 12, 2012 01:29 PM
cutiepiereading
Nov 24, 2011 07:42 PM
tony tiger 54
Apr 30, 2011 02:53 PM
GRC
Jan 21, 2011 04:32 PM
