Scanner advice for No power to pcm escape
Old Dec 19, 2019 | 10:20 PM
Patio1's Avatar
Default Scanner advice for No power to pcm escape
I am trying to diagnose a 2007 Ford escape that blows its F4 ignition switch fuse when the key begins to turn. Since there is no power to the pcm my obdII scanner is of no use.
Are there any scanning options for the key NOT on position.
Thanks
Old Dec 20, 2019 | 09:08 AM
None that I know of.
The way this should be checked is with an electrical diagram to see just what is powered when the key is turned on.
If no diagram is available, then you need to start disconnecting things like radio , ignition, computer, and any add on accessories etc until when you turn on the key it no longer blows the fuse.That is the hard way, but if you have no choice , that is what might be required. A circuit breaker placed in the place of the fuse will prevent having to go through lots of fuses.
A side note,,,,,,,,,,, if you have the owner's manual, it will tell you what circuits that fuse protects and that can save you loads of unnecessary work and time.You confine your checks to those items only.
Patio1
Nov 24, 2019 08:14 PM
Davemac8776
Jan 16, 2017 03:40 AM
Juan
Feb 20, 2015 12:02 AM
nmwagschal
Apr 30, 2012 12:54 AM
escaping
Nov 22, 2010 08:44 PM
