stolen keys
Old Apr 22, 2021 | 03:25 PM
  #11
The Locksmith must have security clearance and be "Certified" in order to gain access to as built security info. Dealerships have that access and only certified locksmiths..They can make and code a key based on your VIN., but still MUST have that security clearance.
With FORScan, you can request an Extended License Agreement and program for PATS. That’s said, you may need to erase all known, and do a fresh programming...
Old Jun 8, 2021 | 11:36 AM
  #12
MatthewRamirez's Avatar
There is no need to stress about the keys as local auto locksmith experts can also make it for you.
Old Jun 8, 2021 | 12:50 PM
  #13
Hi Matt.
In the past if you had the blanks and a key cutter machine , you could make all the keys you wanted.
Today Just about all vehicles have security systems that will not allow a vehicle to run or even start unless the key , which has to be coded to the vehicle, has been coded.That info usually requires a special programming tool and/or access to "As built" info. Some systems will prevent the starter from operating and some will not allow fuel or fuel injectors to work.. If you have some other info, we would like to hear from you, thanks.
Old Jul 16, 2021 | 11:15 AM
  #14
ChrisLyon's Avatar
Definitely, special programming tool is needed to do this task and no locksmith has such tools at all.
malina72
Dec 6, 2022 05:54 AM
EscapeME
Oct 14, 2012 07:35 AM
TERRIACAMPBELL@GMAIL.COM
Mar 18, 2009 01:52 PM
scott
Sep 29, 2006 12:43 PM
firetech70806
Jul 14, 2006 02:12 AM
