2000 excursion cranks but won't start
We bought a used 2000 Excursion & have had 1 issue after the next. The current problem is the engine cranks but will not start. We had recently replaced the catalytic converter & while drivimg the vehicle started jerking. Then wouldn't start back up after turning it off. Later that day it started & we got it home. We found some frayed wires & fixed them. Now, it won't start period. The theft light is not flashing rapidly. Is the pcm bad?
There are several reasons for a vehicle engine not to start and a bad PCM could be one of them,,,but there are other less expensive and more common reasons for a no start.
Since we need to start somewhere some questions may help.
Did you just purchase fuel prior to the vehicle acting up and shutting off ?
Can you provide some background as to what was done maintenance wise other than the converter?
funkdoobiest
Feb 11, 2006 05:16 PM
