2013 Expedition Max Both blower motors quit working
Old Feb 1, 2023 | 05:53 PM
  #11
aquanaut20's Avatar
Do you know how to use it ?
Old Feb 1, 2023 | 05:55 PM
  #12
aquanaut20's Avatar
Keep in mind if there is a high resistance on the circuit, you may have voltage (meter), but no amperage, that is why a test light is preferred (load)
Old Feb 1, 2023 | 06:12 PM
  #13
Bornalbertan's Avatar
Yes, I'm an electrician. The resistor for the front blower was just changed and the wiring harness has signs of getting hot. Im wondering if there is too much resistance due to poor continuity causing it to draw down the voltage to a a point that the main relay drops out. Just a theory.
Old Feb 1, 2023 | 09:34 PM
  #14
aquanaut20's Avatar
If you are wondering about a high draw, check with an amp clamp
Old Feb 2, 2023 | 03:12 PM
  #15
If you want to,
Take out the blower motor and see how free it is to move.
If it has high drag due to lack of lubrication, you will be able to see that and possibly add some oil to the bearings if needed.
Also, if you want to at this time, you can check for how many amps it is pulling , much easier to do when it is out.They do pull a few amps 15-20 would not be too much.
As you know, some wires will get warm with current flowing through them, but should not get hot !
You can also decide to replace the motor if you want to do the job once.
apollo
Dec 4, 2023 01:20 AM
Rory L. Pierce
Aug 14, 2018 02:44 AM
mrvulcan
Apr 3, 2010 11:29 AM
carnieone
Aug 15, 2009 07:54 PM
starrchilde
Oct 18, 2008 04:59 PM
