turn signals
Old Feb 17, 2006 | 11:09 PM
vintrider's Avatar
Default turn signals
Ok, when i activate the turn signal only the rear comes on, and comes on at a very fast speed
nothing on the dash, mirrors, front, only the rear and very fast..... Any suggestions??
it does not do it every time........Thanks........Ed
Old Feb 18, 2006 | 10:52 AM
frdtek05's Avatar
Default RE: turn signals
In most cases a double flash indicates burned out brake bulbs but....!
The multi-function switch (turn/hi-beam/wipers) is a very common problem with those and can give you those symptoms. I'd go the cheap route first by replacing the front bulbs and seeing if it starts working. If not go get a multifunction switch at the dealer(about 160.00)
Old Feb 18, 2006 | 11:34 AM
vintrider's Avatar
Thank You. i will give the bulbs a try first, but knowing my luck it will be the more expensive of the 2. Murphy lives in my spare bedroom!!..hahaha
demonking75
Nov 17, 2008 09:58 PM
Luke 22
Jan 27, 2007 03:26 AM
danny88
Oct 29, 2006 01:07 PM
pilotlars
Aug 20, 2006 09:00 PM
vintrider
Feb 24, 2006 09:00 PM
