Explorer stops running
Old Aug 5, 2021 | 05:16 PM
Steven Hauberg's Avatar
Default Explorer stops running
My sisters 97 Explorer 5L fuel injected up and quits running. Truck wouldn't start until gas was added to the fuel tank.. I think what is happening is no air is being let into the tank and a vacuum is forming. The last time this happened I pushed in the Shrader valve on the furl system and no fuel came out. I thought this was caused by a failing fuel pump but when the gas cap is removed and air is let into the tank , the truck would start and lots of gas came out the Shrader valve. I had a similiar problem with an old Dodge truck I used to own. What would stop air from getting into the tank to prevent a vacuum from forming. Thanks for all your help.
Old Aug 6, 2021 | 11:09 AM
Vent valve , either stuck or filter on valve plugged.
Old Aug 6, 2021 | 12:20 PM
Easy test would be to leave the cap cracked a bit.. On a stall no start, do you hear the pump running?
Old Aug 6, 2021 | 01:31 PM
Thanks I will check it.
Old Aug 6, 2021 | 01:34 PM
I don't hear the pump running. When I push in the shrader (sic) valve on the fuel line, gas spurts out so it has pressure,
Old Aug 6, 2021 | 03:57 PM
The fuel pump run is ‘timed’ on a key cycle to ON/RUN, only on a few seconds active , just releasing the pressure won’t run the pump. On a no start, if you cycle the key, you should be able to hear the pump run, either from the underside, or listening in the fill neck.. It would be best to put a gauge on the schrader and test for spec pressure and volume
gkpische
Nov 30, 2012 12:24 PM
yankees27
Aug 9, 2012 12:36 PM
AlThePalF150
Apr 24, 2010 05:16 PM
Mr. Whipple
Mar 29, 2008 11:04 PM
Julian
Jan 24, 2005 09:38 PM
