Nothing happens when I press start button
Old May 9, 2023 | 11:49 AM
Rexx900's Avatar
Default Nothing happens when I press start button
I have a 2103 ford explorer limited and nothing happens when I press the on button but the radio comes on when I press the power button. I just put in a brand new battery it's not even showing me anything on the display but the mileage at first then nothing.
Old May 9, 2023 | 07:52 PM
Do you know if the stoplights are working?
Old May 9, 2023 | 08:32 PM
Rexx900's Avatar
Default Yes the taillights work
Yes the taillights come on. For some reason even the accessory doesn't work when I press it but I can turn the radio on and off with the radios power button.
Old May 10, 2023 | 06:30 AM
So we are clear, tail lights =parking lights etc., stop lights are a separate system.
Old May 10, 2023 | 06:49 AM
Rexx900's Avatar
Oh okay I understand what you mean about to check I want to say no because I don't recall seeing anything on.
Old May 10, 2023 | 07:58 AM
Rexx900's Avatar
When I turn on the parking lights they do work I can even hear the dinging sound. Just nothing when the button is pressed.
Old May 10, 2023 | 11:27 AM
The reason I asked about the stop lights working was , you must depress the brake pedal in order for the vehicle to start. Th stop lite circuit sends a message to the safety system , OK to start
.If the stop lite circuit is not functioning correctly it could prevent the vehicle from starting just as if you did not depress the brake pedal.
Old May 10, 2023 | 04:11 PM
Rexx900's Avatar
What would make the push button not work at all. Usually you're able to press it and use the accessory power or even see displays but it does absolutely nothing when pressed, but oddly enough the radio will turn on if I press the power but for radio nothing else on the dash shows up.
Old May 10, 2023 | 06:00 PM
Before getting involved in anything, always a good move to check if any fuses are open.
Christie Bray
Jul 10, 2020 08:16 AM
cbrtrvr1
Dec 12, 2017 03:09 PM
sdhoward6
Jul 16, 2010 11:31 PM
quinttheman
Feb 28, 2009 02:04 AM
hdandford
Sep 20, 2008 01:00 PM
