1995 5.8L starting issues
Old Jan 24, 2012 | 12:45 PM
  #11
Usually an overfuel condition will get the converter to the glowing point. Did you get a chance to check the fuel pressure regulator for gasoline in the vacuum line at the regulator?
Old Jan 25, 2012 | 12:18 AM
  #12
Old4xford's Avatar
I just had a similar problem with my cats glowing (yes, there are two on my truck for some weird reason). My problem was caused by one or more cylinders not firing correctly and dumping unspent fuel into my cats, where the fuel was heated sufficiently to burn and burned out the cats. Melted my entire exhaust system.
Old Jan 25, 2012 | 10:24 AM
  #13
bluewind's Avatar
Just last week there was a guy who burned up his cats because the distributor was loose and lost timing.
Old Jan 25, 2012 | 09:09 PM
  #14
causindrama021's Avatar
i believe its clogged and what caused the egr to go bad
dwarber
May 4, 2025 11:31 AM
thund3rchick3n
Sep 6, 2011 04:02 PM
gnorton52
Oct 3, 2010 07:57 PM
The Fuzz 53
Jan 27, 2009 02:18 PM
dominantmind
Nov 13, 2007 01:07 AM
