2006 Ford F-150 runs bad at stop signs after warm and stalls
Old Dec 15, 2017 | 03:40 PM
Tyler1086's Avatar
Default 2006 Ford F-150 runs bad at stop signs after warm and stalls
My 2006 Ford F-150 I recently purchased after getting warmed up to operating temp the motor wants to start running bad and die at stop signs or low rpms. It is driving me crazy!! I changed camshaft sensors and Vct solenoid also gave it an oil change but to no avail. Someone please help!!! Thanks. Tyler
Old Dec 15, 2017 | 05:42 PM
Before we do anything , was the battery recently disconnected and reconnected?
Also remove the intake hose from the throttle body at the mass air flow sensor and check if there is any accumulation of crud/ carbon on the throttle plate and mass air flow sensor that extends into the air intake. If so there is a special cleaner used to clean the sensor and throttle body butterfly. Once that is done the throttle body recalibration should be done so The computer knows the unit has been cleaned and adjusts accordingly. Let us know what you found because it is a little lengthy to explain if not necessary.
Old Dec 17, 2017 | 09:41 PM
Tyler1086's Avatar
Default Problem still occurring.
Ok so I took some throttle body cleaner to the throttle body and it seemed to help the truck a little bit bit the problem is still occurring. The code that comes up now says intake manifold runner control stuck open bank 1. Asked a mechanic buddy of mine and he told me he didn’t think 2006 5.4 had a Imrc?? If it does where would it be located? Thanks.
chad_allen123
Apr 1, 2014 08:37 PM
elitethrilla
Sep 2, 2012 10:28 AM
Videoguybob
Aug 16, 2011 08:19 PM
shosome
Sep 27, 2010 06:45 PM
helpford
Nov 12, 2008 11:35 PM
