94 F150 5.0 want to change differentials
Old Mar 23, 2013 | 01:22 PM
intwtf's Avatar
Question 94 F150 5.0 want to change differentials
My son has a 94 F150 with a 4 inch Suspension lift and running 35X12.5X15
He has stock gears and has been told to change out to 410... is that correct... looking of others to either confirm or say stay with stock.. he just wants to get better mileage and less wear and tear on the engine.. and won't be taking it into mud bogs or anything like that...
Old Mar 25, 2013 | 09:20 AM
grindman's Avatar
is it two wheel drive or four the reason I ask is if you it's four wheel drive then you have to change both differentials to keep the transfer case from being ruined or shelled out. when trying to improve mpg the higher the gear the better the mpg because the engine doesn't have to turn the rpm's that would if it had or has a lower gear ratio
2ndlife
Apr 30, 2010 03:36 PM
darrin
Jan 4, 2009 03:39 AM
dee004
May 8, 2007 08:04 PM
Jessepartida
Jan 13, 2007 12:50 PM
f150harley06
Sep 23, 2006 11:29 PM
