Ball joint Press tool for F-150
Old Dec 3, 2015 | 10:12 PM
skid2964's Avatar
Default Ball joint Press tool for F-150
1995 F-150 2 Wheel Drive...
I need to replace my upper and lower ball joints, Will a ball joint press tool be required? If so, which one? (part number?)...
Thanks
Old Dec 4, 2015 | 05:38 AM
Most auto supply stores sell the tool kit to replace those joints. Requires some special spacers and the clamp alone is not enough. Be prepared to shell out some bucks for a decent kit. Pays to shop around.
Old Dec 7, 2015 | 01:04 PM
Shay_Fox's Avatar
well said Hanky...!!
Old Dec 7, 2015 | 09:11 PM
primem's Avatar
I bought the master adaptor set from napa, it covers pretty much all domestic.
you still need a press kit so scroll through the link.
napa ball joint press kit - Bing images
Old Dec 8, 2015 | 03:05 AM
If you are only planning to use the tool once check if you can rent the tools from an auto supply store. If you buy a cheap set sometimes the job is harder . Good quality tools can make a world of difference with some jobs . It doesn't make a lot of sense to buy a cheap tool and "bust your knuckles" when you can rent a decent one to use only once.
JoeKovacs
May 29, 2011 10:01 AM
bmarnall
Jun 28, 2007 08:23 PM
KREEKVIEW
Jan 2, 2007 10:21 AM
64compact
Nov 2, 2005 08:16 AM
DYI
Mar 28, 2005 11:54 PM
