crank- no start 1997 f150
Old Jul 31, 2024 | 07:17 PM
  #21
montanarick's Avatar
found broken wire on ckp have to get pig tail to repair and then will try again, did a temp fix and truck started and idles for aboput a minute ten died, code came up 320 ignition, distributor, will fix new pigtail tomorrow and will see wat happens then
thank you
Old Aug 1, 2024 | 06:07 AM
  #22
It is a little involved to replace the pick up coil in the dist.
The code is from that component and it's connections.
If you are careful and do a "GOOD" job repairing the connector, you might get away with just doing that.
The dependability of your vehicle will depend on the quality of your job. The connection carries very small amounts of electrical signal and it is critical that the connection is good.
Thank you for the update.
If you decide to replace the pick up coil or dist please check here before STARTING the job.
There is an EXACT procedure to get things in place before disturbing settings.
Old Aug 1, 2024 | 10:02 AM
  #23
is it better to solder the connection or use inline connectors
thank you and will check bach later
Old Aug 1, 2024 | 12:11 PM
  #24
Ford recommends non-insulated butt splice connectors like this:
Amazon Amazon
+ heat shrink tubing.
All the connector replacement you buy regardless of what brand dorman or motocraft, always use that combo, especially in a tight spot, If you are pro at soldering, and when working only on the bench, maybe.
Old Aug 1, 2024 | 09:11 PM
  #25
thank you for all the knowledge you shared. it is running pretty good now. used inline butt connectors and shrink tubing.
thank you on to the next challenge.
Old Aug 1, 2024 | 10:20 PM
  #26
Repaired connector, started truck and let idle for about 10 min. turn off and check codes, no codes, took for test drive check for codes, none
knock on wood , think we got it. Thank you for your knowledge and assistance.
Onto he next challenge
Again Thank you
Old Aug 2, 2024 | 10:17 AM
  #27
Cody Long Sr.
Feb 20, 2020 10:12 AM
renegaderob18
May 15, 2014 08:54 PM
iuecbrad
Dec 22, 2011 08:10 PM
waller
Oct 1, 2011 08:35 AM
akblackdawg
Jul 30, 2011 05:32 PM
