electrical problem
Old Aug 12, 2016 | 09:46 PM
tdutch97's Avatar
Default electrical problem
hello, I have a 97 f150 lariat 4x4. recently the radio lights are not working, the blinkers don't work if the headlights are on. the hazards don't work if the a/c is switched on, the a/c blower motor doesn't work, the fog lights don't work, the harzard arrows on the dash are always on, the instrument panel lights don't work.
had the gem module tested. tested bad. replaced it. same problems. any ideas?
Old Aug 13, 2016 | 03:29 AM
You have a poor ground connection in the vehicle.. Start with checking all the ground connections starting with the negative battery terminal. It is a good possibility one of the ground connections at the front of the vehicle where the sheetmetal gets it's ground.
Most likely in the engine compartment. Many times when guys do engine work they fail to reconnect all the grounds from the engine to the sheet metal.
Old Aug 13, 2016 | 08:43 AM
tdutch97's Avatar
ok, thanks. I'll start checking grounds today. might take me a while to find all the points!
willijimon
Oct 21, 2018 08:07 PM
tigermonroe
Dec 21, 2005 11:06 AM
husky410
May 13, 2005 03:13 AM
husky410
May 11, 2005 06:51 PM
jgramke
Nov 22, 2004 07:40 PM
