F150, bogs down at 55mph 1300rpms
Old Aug 13, 2017 | 07:20 AM
James Troutman's Avatar
Default F150, bogs down at 55mph 1300rpms
So I've been having this weird issue lately with my 05 F150 5.4. It's been going on for a few days now. Everyday I leave for work she'll start up nice and fine, idles smooth at around 950 rpms. Ones I get going for the first couples miles it'll shift smoothly and all is well but once it shifts at around 50-55mph at around 1900 Rpms and drops down to around 12-1300 Rpms after say 5 miles or so, it sorta bogs down like it wants to stall. And it'll continue doing that until I get to where I'm going and turn it off. Then it's the same issue over and over again. It almost felt like the same issue I was having when I replaced the vvt solenoid and cam sensors. But this time it just feels like it loses power and doesn't want to go anywhere. But if I lay on the gas a little it clears up and goes. Doesn't hard shift or anything. Could this be a plug or coil issue maybe? Or maybe a plugged converter? No CEL or codes popping up either. Does also have a slightly rough idle after driving for a bit.
Old Aug 13, 2017 | 02:41 PM
Can I ask what type and kind of motor oil are you using?
Old Aug 13, 2017 | 04:25 PM
I am using Valvoline Full synthetic. 5w30. Was told even though it calls for 5w20 that 5w30 is okay also and helps quiet things down a little bit.
Old Aug 13, 2017 | 06:09 PM
The reason I inquired about the oil was there have been problems with not using the recommended oil. Consider trying the owner's manual choice and see if it helps the VVT system.
Old Aug 13, 2017 | 08:29 PM
I will be due for an oil change here soon so I'll go back to the 5w20 and see if that helps any. The issues just started a few days ago and I replace the vvt solenoid a few months ago so I'm sure it's due. Maybe I'll pull some plugs and see how they look. Truck had had plugs replaced before so hopefully they come out easy. I did have to replace a coil back in November also. Just crazy cause it's not throwing any codes.
teeham
Nov 6, 2015 04:13 AM
BigRedFord
Sep 6, 2012 06:09 PM
llr1231
Jun 3, 2007 12:43 PM
DUCKHUNTER12GA
Apr 16, 2007 09:56 AM
DUCKHUNTER12GA
Apr 12, 2007 09:18 AM
