Jerking and popping f150 1995 5.0
Old Apr 20, 2025 | 06:31 PM
leroymcneilljr's Avatar
Default Jerking and popping f150 1995 5.0
I have a 1995 ford f150 5.0. Having issue with fuel I think. Engine started jerking and popping back through manifold while driving. I have replaced both fuel pumps and fuel pressure regulator. Only reading 22psi on both fuel pumps. This may be the issue not sure. Any suggestions
Old Apr 20, 2025 | 07:32 PM
Pressure should be ,,at least 35-45 psi.
If pressure regulator is staying open more than it should, clamp return line to tank and see if pressure goes up. If it does regulator is defective. If no change in tank fuel pump is suspect.
Before going any further, does vehicle have dual tanks ?
Also are we sure full power, 12 volts, is available at the pumps and is the ground a good connection ?
Old Apr 20, 2025 | 08:36 PM
Yes, it has 2 tanks. Also has 12v going to pump. Used jumper wire to test for voltage 12 volts. not able to clamp return line tonight. Will try that 1st thing tomorrow Thanks for reply hanky. will message you tomorrow.
Old Apr 24, 2025 | 01:45 PM
avensis's Avatar
If the regulator returns too much fuel to the tank because of a clogged or pinched return, the pressure drops
whitebullnose
Apr 21, 2025 12:55 PM
Smitty1019
Jan 19, 2022 07:12 AM
Christy Waddell
Jun 23, 2020 04:35 PM
andrew75
Mar 31, 2016 04:41 PM
robnkim
Oct 3, 2010 07:28 AM
