Struts and shocks
Old May 6, 2022 | 03:07 PM
lyleb's Avatar
Default Struts and shocks
Took 2016 f-150 to shop to check alignment. I had noticed the it felt a little 'off'. Kind of 'floaty' (don't think that's a technical term) or maybe a slight tendency to 'wander'. Truck has 65K miles. They said alignment, bushings, tie rods, etc. were all good, but said I needed new struts and shocks. Does that seem reasonable for a vehicle with only 65K miles. 2WD. Some driving on gravel roads, but they are in pretty good condition. Tires rotated and balanced a few thousand miles ago. Just trying to tell if I'm being sold. Thanks.
Old May 6, 2022 | 06:07 PM
Shocks will not do anything to solve a wandering problem. Struts can influence response on bumpy roads but usually have little if any effect on a wandering problem.
Don't forget rear suspension looseness can affect straight ahead driving especially when the throttle is depressed.
Different tires can have an effect on vehicle control.
Old May 8, 2022 | 01:29 PM
raski's Avatar
I would have someone look again at the ball joints and tie rods. Even with 65k, it's not that uncommon to have loose suspension parts since there's likely no grease fittings to lubricate the joints.Ball joints specifically can cause some wander especially after hitting a bump. Shock and struts are an easy money maker for shops and they often push those items since its a quick repair.
Richard Legg
Sep 11, 2020 07:30 AM
edanielson
May 9, 2016 11:34 AM
young ford
Sep 28, 2010 02:04 PM
Duxoup
Dec 24, 2008 04:19 PM
tennford
Mar 18, 2008 11:28 PM
