1968 F250 390 won't run
Old Apr 4, 2019 | 06:42 PM
Randy Janeway's Avatar
Default 1968 F250 390 won't run
It was running, but not real well, until points and wire from coil to points melted. Replaced plugs, points, condensor, coil, the melted wire, cap and rotor, as well as timing gears and chain. It seems to want to start but won't run for more than 20 seconds. Will be replacing carburetor soon. Any other ideas?
Old Apr 4, 2019 | 08:49 PM
If I understand your description correctly, check the charging system or voltage from ign sw to coil. Could be sending 12 volts to coil all the time or charging system is running away at maximum voltage.
jkann1
Mar 8, 2019 03:06 PM
Asl
Feb 15, 2018 06:06 PM
rickyde2000@gmail.com
Aug 31, 2017 05:50 PM
cima0331
Aug 31, 2017 11:22 AM
Unclefudd
Jun 16, 2015 08:09 AM
