2002 f250 Speedometer stop working
Old Jan 29, 2023 | 10:03 AM
Concreter56's Avatar
Default 2002 f250 Speedometer stop working
Seems like im running out of options.So far I have changed out the Speed Sensor,Checked for any damage to wire housing and checked the fuses that go to the speedometer.No Luck!
Old Jan 29, 2023 | 11:23 AM
Where was the sensor you changed located?
Old Jan 30, 2023 | 10:10 AM
On top of the rear differential
Old Jan 30, 2023 | 10:27 AM
Is there a process to ensure there is power going to my VSS. If with the use of a Multimeter,please let me know how(what setting do I put it on to check) As mentioned in original post I do not see any damage to wire housing but you never know . Thanks
Old Jan 30, 2023 | 11:18 AM
Check on the driver's side of your vehicle's transmission , on the tail shaft housing, there should be a sending unit that sends trans output shaft speed and on a lot of trans that is where the speedometer gets it's speed signal. If you remove it and with the key on spin it, it should register something on the dash unit , does it?
Old Jan 30, 2023 | 11:58 AM
Raining heavy now but will check it out.Does this sending unit have wires going to it?Whats it look like ? Wires that look like those going to VSS ? Thicker gauge wire that look like a coaxial cable? Does the removal require a couple bolt removals or is it more intense ? Thanks for your help !
Old Jan 30, 2023 | 12:51 PM
Should have regular wires going to it. One bolt holds a forked type clamp that holds unit in place.
Sstiras19
Sep 20, 2022 02:04 AM
Amosofhnd
Aug 13, 2020 07:38 PM
bbaehr22x
May 17, 2013 08:20 PM
whiteface
Jun 25, 2010 01:52 PM
JCWIND02
Mar 20, 2007 10:54 PM
