2005 ford f250 5.4L one codes P0600 P2105 U0300
Old Feb 17, 2025 | 10:50 PM
  #11
Power is being interrupted and causing the problem.
You will need to get the Freeze Frame info to see just what is dropping out causing PCM to lose power.. A circuit is opening that supplies power to the PCM and other components..
There is a poor connection that opens when the engine moves..
Old Feb 17, 2025 | 11:10 PM
  #12
Bandit79's Avatar
I wiggled so many wires at idle with nothing but yes in gear foot on brake I can get it to shut down... Hmmm wonder if my reader has freeze frame or do more wiggle..
​​will try in morning see what I find... Weather been bad cold truck is outside good Ohio weather..
Old Feb 18, 2025 | 07:43 AM
  #13
I could be wrong on this, but I suspect a wire carrying battery power to parts of your vehicle has a questionable connection.
That could mean almost anything . Maybe a wire with a break inside.a loose connection, maybe a wire touching an unintended ground.
This is not something you can trace out without a wiring diagram and maybe heiko on this forum may be able to help and come up with one.
Power interruption can include any of the mentioned causes and this may require a good electrical shop to find it.
Don't know at this time if there is any service bulletin for this problem.
Old Feb 18, 2025 | 10:07 AM
  #14
Old Feb 18, 2025 | 10:08 AM
  #15
Can you get another check on vehicle codes ? I suspect some monitors are not being run.
Old Feb 18, 2025 | 10:39 PM
  #16
Bandit79's Avatar
Would not run at idle today at first.. Cluster on and off...
Old Feb 19, 2025 | 09:21 PM
  #17
Bandit79's Avatar
Same codes... The p0600 will come and go but others are there.... You can feel it likes its misfiring before it shuts off but No misfire codes
Old Feb 19, 2025 | 09:28 PM
  #18
Bandit79's Avatar
also Dash cluster still not working... But I never get a check engine light come on .. One scanner will pick up codes other scanner says no codes... Weird by the min...
Rays-F150
Jun 8, 2022 05:59 AM
Grumpy619
Sep 6, 2021 11:41 PM
Rusty Baker
Nov 30, 2018 02:18 PM
alex1970
May 12, 2009 08:59 PM
