2019& newer F-250 door chime solved
Old Aug 8, 2021 | 10:19 AM
GE200F's Avatar
Default 2019& newer F-250 door chime solved
Well for all of those that think you can't disable the door chime on a newer F-250, you are wrong. Out of personal necessity I took my 2019 F-250 to the local repair shop that is well trusted where I live and when they looked at it they said there is no way to turn it off, just like everyone else thinks. I had previously called reputable dealers as well and asked them about it and received the same response as everyone else. What I did find out from my local repair shop is he the schematic for the key in the ignition. It's pretty simple. A power wire comes from the fuse panel (fuse #18) on the passenger kick panel to the key switch and when the key is inserted another wire sends the signal to a computer. So I traced the wire to the key switch and unplugged it. It's the blue/grey wire that goes into a connector on the LH side of the steering column. The plastic is easy to take off of the steering column and you Do Not need to cut the wire. Unplug the connector, pop the red thing out of the connector and use a little pick or screw driver to release the terminal. Its the 3rd wire up from the bottom of the connector. Everything else will still function as it's supposed to with this wire removed. The only thing that is disabled is the stupid door chime when the key is inserted. And it didn't take a genius to figure this out.
Your Welcome!
Old Aug 8, 2021 | 12:44 PM
Let's face it, some of us got it and some of us don't. Thanks for the info.
Old Aug 12, 2021 | 04:53 PM
bismic's Avatar
Good to know (if I ever get rid of my 6.0L).
Old Aug 12, 2021 | 06:11 PM
scott.butler4's Avatar
I could be wrong but I believe that wire is also what keeps you from locking the vehicle with the keys in the ignition.
Old Aug 13, 2021 | 02:46 PM
If anybody decides to try this, strongly suggest either have extra key available or try it with the driver's window down.
lunatic_fringe
Apr 25, 2015 02:24 PM
moto4
Oct 24, 2012 08:44 AM
NewToMe2007Ranger
May 9, 2009 08:40 AM
ugbandtulsa
Feb 25, 2009 11:56 PM
rmorse
Jan 18, 2009 09:49 PM
