92 F350 7.3 engine compartment wiring diagram
Old Sep 3, 2025 | 09:45 PM
rhensonsr's Avatar
Default 92 F350 7.3 engine compartment wiring diagram
I have a 1992 F350 with the 7.3l diesel. I smelled a electrical burn then the engine died. Could not find a burnt wire and noticed the fuel pump was not pulsing, so I ran a jumper to the positive line on the fuel pump and it started right up. Drove it home and the key would not kill the engine until I disconnected the jumper. Does anyone have a wiring diagram so I can find the short? TIA!
Old Sep 4, 2025 | 04:38 PM
Diagrams-ALL index page show above.
Remove the 2 bolts and take off the cover, then you can see the fuel shutoff solenoid, remove and bench test it.
Locate C1000 above.
Old Sep 4, 2025 | 09:45 PM
rhensonsr's Avatar
Thank you so much! I will check it Saturday and post what I find.
zeroroadkill
Mar 27, 2025 07:07 PM
Jsikich
May 2, 2023 06:46 AM
zeroroadkill
May 15, 2022 06:08 PM
eric hoffmeyer
Oct 24, 2013 06:47 AM
Jcurtis
Feb 22, 2010 08:31 PM
