Dumb mistake - help?
Old Jan 25, 2011 | 09:14 AM
KentW's Avatar
Default Dumb mistake - help?
With a little help from a friend and the dark of night, i now have winshield washer fluid in my brake fluid on my F-250. I suspect about one-fifth of a gallon.
What is the next step? does it need to be completely drained and filled with fresh fluid?
Old Jan 25, 2011 | 01:04 PM
You could try to remove as much of the mix as possible first, then, yes, a thorough purge of the entire system is the best suggestion I could offer.
Old Jan 27, 2011 | 02:59 PM
fishnfowlr's Avatar
Have you pressed the brake pedal since you discovered this? If not, you might be able to get away with suctioning/vacuuming out all the fluid and replacing it with brake fluid. If you pressed the brakes even once, I would do a complete purge.
jd637
Feb 22, 2019 08:14 AM
jborushko
Dec 22, 2016 08:06 PM
sonjan
Oct 2, 2009 10:56 AM
lobo46222
Mar 19, 2009 10:48 AM
whitecrystal1
12
Aug 18, 2006 12:22 AM
