fuel system
Old Dec 8, 2024 | 10:26 AM
busbar's Avatar
Default fuel system
i have a 1988 ford f250 351 v8 and i have a single fuel tank and my fuel reservoir cracked but i can't find a replacement but can i use a dual tank setup in its place even though i don't have a 2nd tank. thanks
Old Dec 8, 2024 | 01:32 PM
Does your vehicle have 2 fuel pumps, one in the tank and one next to the chassis rail under the driver's seat?
You might try ,
Vintage Parts Inc.
Located in Beaver Dam ,Wisc.
1-879-846-8243
Old Dec 9, 2024 | 06:55 AM
busbar's Avatar
You might try ,
Vintage Parts Inc.
1-879-846-8243
Yes 1 in tank and 1 on frame rail
Old Dec 9, 2024 | 05:37 PM
Did your vehicle at one time have a duel tank set up ?
Old Dec 11, 2024 | 12:35 PM
busbar's Avatar
no it didn't
Old Dec 11, 2024 | 03:06 PM
The info I have does not show that set up for F series. It does show it for E series and Ranger.
All the reservoir does is to insure a constant fuel supply, maybe if the tank is near empty it would help. I see no other good reason for it on the vehicle in question.
Old Dec 11, 2024 | 06:09 PM
busbar's Avatar
okay thank you very much i will bypass it and see what happens
Old Dec 11, 2024 | 06:51 PM
Don't forget you need to have a return from the fuel pressure regulator back to the fuel tank..
I believe there were 2 lines going to the reservoir and 2 lines coming from the reservoir.
One line from the in tank fuel pump to the reservoir , one line from the reservoir to the hi press pump then one line from the fuel press regulator to the reservoir and one from the reservoir back to the fuel tank..
Make sure this is what you have presently.
I cannot suggest altering anything from original.
Were you able to get anywhere with Vintage Parts Inc ?
Old Dec 11, 2024 | 07:04 PM
busbar's Avatar
that's what I'm going to do thanks
JDSully1
Aug 17, 2024 07:47 PM
SuperDutyCJ
Jun 16, 2024 09:15 PM
two bit okie
Apr 27, 2012 12:15 PM
donnie beasley
Dec 12, 2011 03:14 PM
khmoffat
Dec 12, 2006 11:06 AM
