Ignition coil connector
Old Aug 12, 2022 | 02:02 PM
Maggie61's Avatar
Default Ignition coil connector
1989 f250 5.0 while disconnecting the 4 pin connector for the coil. I evidently pulled wires from connector. Can anyone tell me the order of the 4 colored wires that go into this connector?
Old Aug 12, 2022 | 04:47 PM
Does your vehicle have the 2 inch round coil or a different one.
The info I have shows the old style oil filled coil , is that what is on your vehicle?
Also tell us the wire colors and maybe we can come up with where they go.
Are the colors RED-LT GRN (2) wires
DK_GRN-YEL (2) wires
Old Aug 13, 2022 | 09:57 AM
Maggie61's Avatar
looking at the back of the connector where wires go in, position 1 on left has brown wire with white stripe, #2 pulled out (red or green) #3 pulled out (red or green) #4 white with dark stripe,
looking at new coil from NAPA shows --- on left + on right, Both, wires had same spade connector on the end, I went with red in pos #3 snapped and locked right in, Green was very difficult to push in pos #2 upon closer inspection of #2 port the inside was wedged shaped while wire end was aprox 1/8x1/8 square, seemed as this was a pressure fit compared to the red in pos, #3 snap and click, Better suited for a ground ?? need to finish more repairs before i can fire it up, thank you for your response
frprof
Sep 26, 2020 07:35 PM
Cale
Apr 9, 2019 10:11 AM
rickyde2000@gmail.com
Aug 31, 2017 05:50 PM
57 huddy
Jan 16, 2017 09:04 PM
letsbangout
Feb 13, 2014 05:45 PM
