No power...
Old Oct 28, 2022 | 10:52 AM
Gravesstl's Avatar
Default No power...
Bought a low mileage 2005 Ford F250 XL Crew Cab with a 5.4L a little over a year ago. I needed it to pull a camper. Well, the truck acts like it is dragging when it's being driven and loses significant mph on even a slight incline when pulling the camper. The camper is way under the tow capacity (by almost 1/2) for the truck and I've had a mechanic buddy help me with going through the air intake and the exhaust and can't find anything.
Just this morning the check engine light came on and I have codes P0171 and P0430. I know it's not the catalytic converter because we just tested it a couple of weeks ago. At lunch today I'm going to listen to hear for a vacuum leak when I shut off the engine. I'm getting a Mass Air Flow sensor and will replace it Sunday, but does anyone have any other suggestions? I'd rather perform the work myself if I can...
Old Oct 28, 2022 | 03:06 PM
You have to check for vacuum leaks with the engine running.
This is something you might consider having an experienced shop handle for you.
Old Oct 28, 2022 | 03:09 PM
Gravesstl's Avatar
Will do. I'll have to get that done on Sunday and check back with the group. Thanks!
F150-07-4.6
Jul 19, 2018 07:13 AM
Shelbatron
May 21, 2010 10:50 AM
gemini0409
Jul 14, 2007 03:08 AM
overkill42
Aug 24, 2006 11:32 AM
Buckskn1
Jun 13, 2006 01:06 PM
