No Power! No Warning
Old Aug 11, 2024 | 02:58 PM
Dprats's Avatar
Default No Power! No Warning
Is it possible to just loose power and have no battery life without warning? Even after charging batteries.
batteries are only 5 years old. 2019 f250 Lariat.
Old Aug 12, 2024 | 04:00 AM
You need to check all your wiring and connectors. Also use a voltmeter to verify the voltage to see if the battery can hold the charge or not. The charger might indicate the battery is fully charge after 5+ hours and you might get 12.75V when you disconnect the charger. You wait an hour you check the battery voltage with a voltmeter if you get below 12V then your battery is probably bad. If yours is a "flood" type (not maintenance free type), after a full charge pry off the 2 caps on top and check the water level, add only distilled water, don't overfill it, one inch down from top at least, then recharge again. If your battery can't hold a charge still, and if you use ctek or noco charger you need to run repair mode as your last resort.
Old Aug 12, 2024 | 09:04 AM
Please describe as best you can exactly what is or is not happening, maybe we can offer some things to help, thanks.
Old Aug 13, 2024 | 06:14 AM
Dprats's Avatar
Default Seems to be batteries
Thanks for all your suggestions. I did check the batteries after they had been charged. They were not holding the charge.
It just seemed so strange that the batteries died with no warning. They were the original batteries. The batteries on my last ford pickup lasted 15 years. I guess they don’t make them like they used to. Thanks again.
Old Aug 13, 2024 | 10:12 AM
There are clocks, and all sorts of memory that consume power even with the vehicle shut down and that explains why they don't seem to hold that charge.
Although the power consumed is small a good battery should hold a good charge for days.
When you say batteries, are you saying your vehicle has more than one battery ? Please clarify, thanks.
Old Aug 13, 2024 | 09:25 PM
Dprats's Avatar
Default 2019 Ford F250 Lariat
Yes. This Pickup has a power inverter. It came with two batteries. It’s a gasoline engine. It definitely has every option. I can see how the battery takes a beating. My pickup sits for weeks at a time. I don’t use it much anymore. Been driving a company vehicle. I tested the batteries Will the engine is running. The voltage was at 14.8 volts.
Old Aug 13, 2024 | 10:41 PM
It really depends on how much you use the inverter, Ford's dual battery factory setup was never designed to run any inverter, you need a custom setup.
Dual batteries with inverter, please read thru this thread: https://www.fordforum.com/forum/othe...08-f450-49184/
Old Aug 14, 2024 | 11:34 AM
Dprats's Avatar
Default Great info.
Thanks for the advice and information on power system. I will definitely consider this in the future.
Deliveryguy
Sep 14, 2022 06:38 PM
LexiB32
Jun 23, 2021 06:11 AM
Doc Holladay
Jul 8, 2020 05:08 PM
Mystic P Bleu
Jul 24, 2018 05:26 PM
Timmy
Sep 26, 2006 03:42 PM
