Truck won't shift into gear
Old Aug 9, 2021 | 05:09 PM
Jcalhoon123's Avatar
Default Truck won't shift into gear
I have a 1985 ford f250 3/4 ton with a 460 that I replaced the clutch, pressure plate and flywheel and it will not go into gear now. I made sure clutch plate isn't backwards, torqued flywheel and pressure plate to spec. Clutch pedal adjusted, and bled the the slave cylinder. Clutch fork is on the throw out baring and fully engaging pressure plate. I have no idea what to do other then try a different clutch kit.. Any advice would be greatly appreciated!
Old Aug 10, 2021 | 07:17 AM
Did you have this problem before replacing the clutch assy?
Old Aug 10, 2021 | 01:02 PM
Other than 4th gear was slipping it was fine.
Old Aug 11, 2021 | 02:15 PM
See if you can tell if the release bearing is moving the fingers of the pressure plate enough to take pressure off clutch disc. There may still be a problem with the hydraulic system
Maybe all the air was not completely removed.
Troy Brooks
Apr 6, 2018 06:37 PM
CatfishM3
Jan 13, 2016 01:24 PM
99Ran
Jun 18, 2015 07:16 AM
jake_ryg92
Jan 22, 2009 10:35 AM
adb135
Sep 18, 2006 11:29 PM
