2006 After several cranks it will start rough..
Old Nov 19, 2023 | 04:48 PM
brandonsanmiguel's Avatar
Arrow 2006 After several cranks it will start rough..
It started happening in September after i replaced the battery and alternator. Since then I replace the spark plugs, cleaned the throttle body, and replaced fuel filter. I had been driving it since July w/o any issues. Long story it was my grandmothers car and i took it over when she passed this summer. It had been sitting at her house for a while when she was unable to drive or my mom would take her places in her car. My uncle would take it out every once in a while per year to run it. Great car.. 69K miles on it.
Got this from my ODB2 Xtools scanner
60 Off Indicator Lamp Of Fuel Cap Off
61 Fuel Level 0.000 0.000 0.000 %
62 Fuel Pump 1 75.000 82.500 67.500 %
63 Fuel Pump 2 Off
64 Fault Of Fuel Pump No Fault
65 Fuel Rail Pressure 20.823 22.905 18.741 psi
66 Fuel Rail Pressure(Sensor voltage) 1.691 1.860 1.522 V
67 Fuel Pressure 8ms Sampling 1 6443.000 7087.300 5798.700 ms
68 Fuel Pressure 8ms Sampling 2 39.679 43.647 18.741 psi
69 Desired Pressure Of Fuel Rail 39.686 43.655 35.717 psi
70 State Of Fuel Rail Pressure Transducer No Fault
71 Temperature Of Fuel Rail 68.0 74.8 61.2 deg F
72 Temperature Of Fuel Rail(Sensor voltage) 3.242 3.566 2.918 V
73 Pressure Of Fuel Tank(Sensor voltage) 2.507 2.758 2.256 V
74 Pressure Of Fuel Tank -30.03 -27.03 -33.03 psi
75 State Of Fuel Tank Pressure Transducer No Fault
76 Pressure Of Fuel Tank Is Displayed As Inches Of Water. -0.83 -0.75 -0.91
77 State Of Fuel System (Open/Closed Loop) Loop Is Open.
78 State Of Fuel System (Open/Closed Loop) - Bank 1 Loop Is Open.
79 State Of Fuel System (Open/Closed Loop) - Bank 2 Invalid value
80 Command Of Generator 1.279 1.407 1.151 %
81 Fault Indicator Lamp Of Generator On
82 Monitor Of Generator 1 Low
83 Monitor Of Generator 2 0.000 0.000 0.000 %
File Type: mov
Old Nov 20, 2023 | 11:26 AM
There is one more thing we should know and that is ,
when cranking the engine over to start, what is the voltage reading at the battery at the time the starter is working?
dhsvcs
Apr 26, 2023 01:19 PM
saemetric
Jul 23, 2015 01:41 PM
raymo46
Apr 29, 2012 07:33 PM
pilleway
Jul 9, 2011 10:50 AM
digby
Mar 19, 2009 04:08 PM
