No Crank Throttle Body Clicking
Old Mar 21, 2025 | 11:03 PM
  #11
BlackReaper's Avatar
You might try a forced reset that consists of removing the negative battery cable from the battery, and while disconnected turn on the headlamps. This will erase any programmed faults.. Then you can reconnect the cable back onto the battery, start the engine, BUT do not touch the throttle pedal until after the engine speed settles down.
Let us know if it got rid of the starting problem..
Just tested and the car still didn’t want to crank. The throttle body continued to click and when I turned the key nothing.
Old Mar 22, 2025 | 05:35 AM
  #12
Can you remove one other plug,like the air intake temp,and see if you get the same result of the clicking to stop ?
This could be one way to verify if there is a problem with the power supplied to the system. It is called V ref. and should be around 5 volts.
Is there any way you might be able to measure that voltage and verify it is not being pulled down by one of the components supplied, which could be shorted internally ?
Old Mar 22, 2025 | 11:09 AM
  #13
I pulled the MAF sensor and there wasn’t any change. I took the battery to a store and they said it was low. Got it charged, but no difference when starting. Still getting that clicking from the throttle with no crank. I cleared the codes via my two scan tools and still nothing. Only codes I can pull are when the throttle is disconnected and they are all throttle body related.
I can go purchase a multimeter today so i can do some more further testing. At my wits end with this, I’m thinking it has to be wiring or ECM related. Any ideas on what i should try next? Thank you!
Old Mar 22, 2025 | 11:41 AM
  #14
Originally Posted by heiko
You said you only tighten the spark plug bolt that's why I gave you the torque specs you might want to double check. And during the spark plug bolt re-tightening last night you might have pulled other wire/connector. Yes, the loose connector/wiring I mentioned I was referring to the wiring at your TPS/throttle body. So it can definitely be a wiring issue.
I double checked the connections and everything was plugged in. The bolts were torqued correctly. Any advice on what to try next? Thank you so much!
Old Mar 22, 2025 | 03:26 PM
  #15
You can try the pinpoint tests I attached previously at: https://www.fordforum.com/forum/ford...driving-50100/ It's all about testing the TPS.
And when you have a no crank no start issue, you might want to look at the starting circuit, check pdf below, you can begin at A4. Only if you have crank no start then you look at air+fuel+spark.
Old Mar 24, 2025 | 12:18 PM
  #16
i did figure out something, if i unplug the vapor canister purge valve the ticking from the throttle body will stop. I am hearing the purge valve also when i turn the key on.
I’m going to try what heiko sent and update later tonight.
Old Mar 26, 2025 | 04:16 PM
  #17
So i have an update. It was fuse 49 causing the issue! The test light showed it was working but when i pulled it out it was burnt out. I put in the fog light fuse and the car started!
Old Mar 26, 2025 | 07:31 PM
  #18
Thank you for the update.
If you had power TO the fuse , did you have power at the other side of the fuse ?
Old Mar 26, 2025 | 09:51 PM
  #19
BlackReaper
Mar 6, 2025 08:26 PM
Jack1985
Jul 20, 2024 11:12 PM
sarxworks
Mar 10, 2023 12:30 PM
michaelboycehenry
Oct 1, 2022 02:51 PM
cbyers
Oct 20, 2010 12:09 PM
