2016 ford focus mystery coolant leak
Old Aug 7, 2018 | 11:00 PM
Wiskeynguns556's Avatar
Default 2016 ford focus mystery coolant leak
My ford has a leak I haven't found it yet. But when I go on a trip I check it (trips every friday) and it is really low what could be the issue?
Old Aug 8, 2018 | 03:29 AM
We use a cooling system pressure tester to increase pressure in the cooling system to about 15 lbs and observe if the press drops . If so then we start searching for where we can see the leak. Most leaks take place when cold and everything contracts.Some only leak when the temp of the engine rises and now the leak shows up.
If no external cause is found then we start looking for internal problems. I could be wrong , but I wouldn't expect a 2016 year vehicle to have anything serious wrong. There should be some kind of warranty on the relatively new vehicle and have you had the dealership check this out?
Old Aug 8, 2018 | 08:18 AM
Bought at an auction no warranty that 9 was told about
Old Aug 8, 2018 | 02:20 PM
I would check with a dealership anyway, you may have some luck there..
Sage
Jan 20, 2022 10:32 AM
Denver Burns
Dec 27, 2018 02:15 AM
Vinyard
Dec 4, 2017 09:13 AM
txrebel1988
Oct 28, 2011 09:06 AM
mark2005
Mar 9, 2006 01:15 PM
