96 bronco keeps dyeing .....help
Old Jan 31, 2023 | 07:37 AM
  #11
There is a test that you can do to verify if the coil is opening as it gets heated ,or just replace it, if still original coil.
There is also a pick up coil in the dist that could be experiencing the same problem , in which case the dist has to be removed in order to replace it.
I would suggest trying the ign coil first and if that doesn't help consider the dist pick up coil.
There is a certain procedure to follow before you remove the dist if you have to go that route. If you are familiar with it fine, if not, the procedure is a little lengthy , but if you follow it exactly, you won't even need a timing light to verify all is right.
Annamaytru
Oct 16, 2021 03:57 AM
Vaughn
Nov 29, 2020 10:33 AM
Huntress2u
May 12, 2018 04:16 PM
CodyPittman
Sep 26, 2013 10:32 AM
Anita
Mar 2, 2007 04:26 PM
