car starter death of my car?
Old Jan 18, 2011 | 04:36 PM
dman's Avatar
Unhappy car starter death of my car?
i just purchased a mercury sable, i know this is a ford forum but it is made by ford and all. a couple days ago my starter went, got it replaced and the car has been running great. till today, when i decided to use my automatic car starter, the car started but the starter would not stop engaging, even after i hit the brake which should auto shut off everything as the keys were not in the ignition.
guess my question is: did the automatic car starter cause this issue? could the starter not have dis-engaged because the mechanic that put the new starter in didn't hook it up correctly to communicate with my automatic car starter?
also, the only way i could get the starter to stop was to unplug the battery, if i plugged the battery back in, boom the car is trying to turn itself on.
any insight would be greatly appreciated!
Old Jan 19, 2011 | 03:28 AM
If the car started fine UNTIL you used the auto starter, I would suspect something in the automatic starting system is not right. You might want to check the remote out first.
Desert Stephen
Jun 18, 2012 02:23 PM
grandgallop
Dec 29, 2010 11:58 PM
BRAVOZULU9
Jun 15, 2008 10:20 AM
needhelp
Aug 22, 2007 03:41 PM
jdm
Feb 26, 2006 08:38 PM
