Need Help.
Old Aug 11, 2012 | 08:12 PM
littleG's Avatar
Default Need Help.
I have a 87 Ford Ranger 2.9 v6 Automatic I pulled the transmission to replace the seal and now it wont start no fire or no power to the fuel pump. I have done tested the ignion module and the coil and checked all the fuses. can anybody help me on this Please?
Old Aug 11, 2012 | 08:18 PM
Did you forget to hook up all the ground wires you disconnected?
Old Aug 12, 2012 | 08:53 AM
bandit1948's Avatar
sounds like some wires pulled loose when you dropped the transmission !
Old Aug 12, 2012 | 07:20 PM
littleG's Avatar
Default need help
Everyone keeps telling me that it sounds like a ground problem But man I have checked everything I am just at my witts end with it . I have found no loose wires hanging down yet.
Old Aug 12, 2012 | 08:14 PM
thexlo8ers's Avatar
Check for a tripped fuel pump cut-off inertia switch.
I think on a '87 Ford Ranger it's located passenger side kick panel.
jd637
Feb 22, 2019 08:14 AM
jborushko
Dec 22, 2016 08:06 PM
BigRig Mechanic
Feb 26, 2009 06:12 PM
streetbob
Jun 17, 2008 05:01 PM
Adhd
Feb 3, 2008 09:55 PM
