Starting issue
Old Jan 27, 2023 | 12:03 AM
Karl graves's Avatar
Question Starting issue
I have a 2005 Ford f150 has new battery new alternator new starter and still won't start not even a click
Old Jan 27, 2023 | 07:54 AM
aquanaut20's Avatar
You need to chase the circuits, both power and grounds.
Old Jan 28, 2023 | 02:42 PM
If you have a second working key, try it.
Old Jan 28, 2023 | 04:07 PM
My 2005 Ford f150 has new starter battery u get instrument lights but no cranking what is problem
Old Jan 28, 2023 | 08:56 PM
What does your anti-theft light on the dash do when you attempt to start the engine?
Old Feb 1, 2023 | 01:14 PM
It goes out
Old Feb 1, 2023 | 01:23 PM
aquanaut20's Avatar
You have a poor connection in the main power circuit, the light goes out when you attempt to start because the circuit cannot supply any current (amps).
If it was an immobilizer issue or bad key, the engine would crank but not start.
Old Feb 2, 2023 | 03:20 PM
May not even crank over because the immobilizer system will not allow the starter to engage.
Old Feb 16, 2023 | 09:52 PM
What and were is immobilizer
Jplii
Jan 16, 2022 04:47 AM
Jackieboehm
Mar 28, 2021 08:01 AM
Russ Jensen
Jul 19, 2019 03:49 PM
Justin Wyckoff
Feb 25, 2019 04:32 PM
Amalia Bailey
Aug 15, 2018 04:46 PM
