Cam Shaft Timing Mark?
Old Aug 19, 2007 | 12:46 PM
arrowshooter's Avatar
Default Cam Shaft Timing Mark?
My son's 96 Ranger with 2.3 broke the timing belt on the highway. After replacement the truck will not start. While we were in there I noted that there are two marks on the cam pulley, a diamond and an arrow. We used the diamond because someone had put a white mark on the gear there. Is this correct. We checked for TDC by watching the exhaust valve cycle up and then then watched for the piston to come back up again. Also, does the second drive pulley do anything other than drive the oil pump? I figured that this truck does not have a distributor, so there should be no other connection. And lastly, could there still be bent valves even though this is supposed to be a "non-interference" motor? Thanks.
Old Aug 19, 2007 | 09:20 PM
Default RE: Cam Shaft Timing Mark?
Never mind, got it. Triangle Triangle, Diamond Diamond.
BASSHAWK
Mar 28, 2012 02:27 PM
kjellesed
Aug 24, 2009 05:24 PM
Qaiphyx
Apr 4, 2008 11:59 AM
GOSFAST
Feb 5, 2007 08:49 PM
Aussie Explorer 98
Nov 13, 2005 02:19 PM
