Fuse 43 -A/C relay coil, IAC, MAFS, HEGO,
Old Nov 30, 2011 | 06:01 PM
Gadgetman's Avatar
Default Fuse 43 -A/C relay coil, IAC, MAFS, HEGO,
I have a 2008 Ranger 3L manual trans. It "hitched" the other day and started running very poorly. It also keeps blowing fuse # 43 which is:
CMS, VMV solenoid, EGR
solenoid, Heated PCV,
Any ideas as to the cause???
Old Dec 1, 2011 | 02:11 AM
As you know, whenever there is an excessive current draw in a circuit either by a partial or complete short it will cause the fuse to blow. What you can try is to disconnect each of the items the fuse controls individually and watch for which one when disconnected allows the fuse to stay without blowing.
There are other ways to do this without replacing fuses every time you try this , but I don't know what equipment you have to work with like a multimeter or circuit breaker to insert in place of the fuse.
Could you let me know that?
Old Dec 3, 2011 | 04:59 PM
Gadgetman's Avatar
I tried unplugging a whole bunch of stuff, after replugging it all back in, it was OK.....Scary to say the least!
Old Dec 4, 2011 | 04:37 PM
In the process of unplugging and plugging you may have moved some wires that were touching something and providing a path to ground. Glad you solved the problem.
Charbel Zgheib
Oct 25, 2013 09:13 AM
Freewalker
May 19, 2012 09:58 AM
genaod
Oct 28, 2007 10:41 AM
rncdl
Jun 16, 2007 11:33 AM
rlevy64614
Jun 8, 2007 08:55 PM
