speed sensor
Old Aug 17, 2013 | 10:51 AM
paparottie's Avatar
Default speed sensor
I have a 2000 ranger stepside, check engine lite and abs lite are lit up. I have no speedo or odometer working.checked trouble codes and it says speed sensor is bad, changed speed sensor in the rear end,cleared codes, but engine lite and abs lite still on and still no speedo or odometer working. anyone have an idea on how to repair this problem.
Old Aug 25, 2013 | 01:44 PM
go-part's Avatar
Former Sponsor
Have all of the fuses been checked?
Ford Ranger Speedometers - How They Work
Old Aug 27, 2013 | 05:34 PM
paparottie's Avatar
have ckecked all fuses and they are all good, any other fixes or ideas would be appreciated.
Old Aug 28, 2013 | 10:34 AM
diyautoelectric's Avatar
Is there also a speed sensor in the transmission ? Are you still getting the same check engine code? What is the Code ? And what ABS code are you getting ?
Old Aug 31, 2013 | 11:30 AM
paparottie's Avatar
no speed sensor in the tranny, the code is p0500 check speed sensor,don't have abs so I don't know why the light comes on but still have the problem. replaced the speed sensor twice,checked wiring no issues. anymore ideas????
Old Aug 31, 2013 | 12:15 PM
I believe that code kinda says a speed sensor malfunction which usually means the info the PCM is receiving is not rational. Since you don't have an ABS on the vehicle the sensor may be responsible for the signal for the speedometer to work. Some speed sensor circuits also have other sensors on the same circuit. I don't know if this is the problem with your vehicle, but if you have the means , check the 5 volt reference circuit that originates from the computer and supplies some other sensors in that circuit. If it is low one of the sensors in the circuit could be shorted. That could also be the reason for the CE lite. Do you want to get into that possibility?
Old Aug 31, 2013 | 05:59 PM
paparottie's Avatar
Thanks for the help, but I think I'll leave the problem up to my mechanic to fix.
Geoff Riehl
Aug 18, 2012 12:35 PM
alphaeus
Apr 2, 2012 11:34 AM
superdavefarmer
Feb 22, 2008 08:50 PM
gmm
Jul 22, 2005 11:09 AM
abaca
Apr 18, 2005 03:05 AM
