transmission quit changeing gears
Old Feb 14, 2010 | 10:07 AM
bob72's Avatar
Default transmission quit changeing gears
someone told me this is due to the slave cylinder going bad,i have looked and the hose from the master cylinder is going into the top of the transmission was hopeing someone could gve me an idea on how i have to change this it is an 87 ford ranger with fuel injection and a 4 cylinder
Old Feb 15, 2010 | 10:09 AM
digital_diversion's Avatar
standard transmission?
give more information... you push in the clutch peddle and clutch not disengaging? you push in clutch and gearshift wont come out of the gear its in?
describe in detail what your problem is...
Old Feb 15, 2010 | 01:40 PM
hotrodstude's Avatar
some of the japanese transmissions have the cyl. inside the bell housing or use a hyd. throw out bearing?you probley have a madza trans.
Old Feb 19, 2010 | 08:43 AM
ralphie250's Avatar
a 87 ranger uses a mitsubishi 5 speed. that one has the hyd line that goes in the top of the trans a mazda 5 speed the hyd line goes into the side of the trans
Steve Brisbois
Mar 25, 2020 11:44 AM
Longjohns
May 20, 2015 01:40 PM
mohdalmr
Jun 29, 2007 10:15 AM
detroitmi
Aug 16, 2006 12:49 AM
flashrulez
Sep 27, 2005 12:53 AM
