01 Escape Engine Light
01 Escape 3.0 v6 4x4, the engine light was on for some time, I finally got it in to my local shop, code indicated bad DPFE sensor, replaced and I drove 25 miles, light back on, shop says bad sensor and replaced again, no charge, 25 miles later the light is back on. They have now replaced the DPFE sensor 4 times and short wire harness once, the light always comes right back and the code indicates bad DPFE sensor.
Is there anything else they should be looking for ?
_________________________________
Tomorrow will be better!
ChinaSinoy
It might pay to look a little deeper into the DPFE system. Bluewind may have a good point by referring to the vacuum hoses that connect from the EGR orifice to the DPFE sensor. Also the system should be checked for blocked passages with carbon.
Kranden
Mar 19, 2013 04:01 PM
aangel
Jan 16, 2009 03:01 PM
