2006 F-150 transmission output tailpiece
Old Jun 19, 2020 | 08:35 PM
Todd123's Avatar
Default 2006 F-150 transmission output tailpiece
I was wondering if there is a specification for the transmission output shaft play where it connects to the first U joint. I replaced the output shaft bushing in the tail of the transmission. Before I put the bushing in, I slid it on the output shaft to see how tight it was. I thought it was fairly tight and measured each part separately to determine there was only a few thousandths of play. Once I put it back together I put a dial indicator on the flange right by the U joint which is maybe 3" from the bearing area. I measured about .030" of play if I grab the shaft and move up/down and side to side. I am sort of thinking that the output shaft spline area may be worn a bit. Thinking perhaps a tailpiece replacement would be good. Does anyone have a specification for this measurement or experience with it? The output shaft diameter is consistent and measures the same over the length where it would touch the bushing.
2006 F-150 4.2L long bed
2 wheel drive
88,000 miles
Old Jun 20, 2020 | 04:57 AM
raski's Avatar
Excessive play will cause the shaft to wobble, creating excessive wear and vibration. 0.030 seems excessive. There is a bushing in the tail shaft which could be worn.
Old Jun 20, 2020 | 05:59 AM
Will that amount of ply affect the longevity of the output shaft seal?
rfxcasey
Jul 12, 2017 04:11 PM
rdoble
Jan 5, 2009 05:20 AM
brit0817
Feb 12, 2008 03:16 PM
rixxx93gt
Jul 14, 2006 02:22 AM
a1parrothead
Feb 2, 2006 07:20 PM
