Cars shuts when using wiper or engaging a/c also abs brake lights on
Old Sep 28, 2018 | 11:55 AM
Misterg's Avatar
Default Cars shuts when using wiper or engaging a/c also abs brake lights on
after replacing a water pump in my v6 2003 escape i got a buttload of problems
abs and brake light comes on when accel past 10 mph
wipers shuts off engine on any setting
ac shuts the car down
ive heard of cps sensors fixing this issue i may have a spare one on an older motor please any additional insight im currently having a no start issue wants to turn over 1/4 revoltion before it stops
Old Sep 28, 2018 | 02:10 PM
There have been times when an insufficient or disconnected ground wire brought problems like this. Might be a good idea to check and confirm all the ground wires starting at the battery and going on to the sheet metal of the vehicle.are connected and in good condition. There is always a possibility you might have forgotten or overlooked one of them in the process of replacing the water pump. Also , a good idea to check everything you might have moved in the process, never hurts !
Old Oct 1, 2018 | 11:05 AM
Misterg's Avatar
Thanks, i had the battery test ok, is there supposed to be continuity between the neg bat terminal and neg end going to the fuse box? I have continuity in all ground points i checked thus far except there i noticed its the loom the is going to the ecu
Old Oct 1, 2018 | 02:51 PM
I hope your last post has a typo in it, because,,,,,,,,,,,,, the negative terminal of the battery should connect to the engine and sheet metal of the vehicle.
Only the POSITIVE ( + ) TERMINAL OF THE BATTERY SHOULD CONNECT TO THE FUSE PANEL !
Let us know if the cables were reversed before going any further !!
Old Oct 1, 2018 | 09:10 PM
Misterg's Avatar
Sorry for being vague yes the neg battery terminal is connected to the frame from their it goes into a loom that goes towards the ecu, the fuse box in the engine bay has two electrical wires going into it one is yellow one is red. What i did was i put one of the multimeter leads on the neg battery terminal and the other lead from the multimeter to the yellow one on the fuse box. Is that irrelevant?
Old Oct 3, 2018 | 06:44 PM
Misterg's Avatar
Ok so after having the battery out for 2 days then put in jiggled areas of the harness, all is fine, i can only suspect somettimg in the pats from undoing the battery during the water pump fix
Affection2014
Apr 28, 2019 12:43 PM
Hueycrew
Jan 24, 2019 07:06 PM
WildHammer
Dec 20, 2018 04:13 PM
Geggabc05
Feb 22, 2015 12:19 PM
fordka
Nov 12, 2011 10:18 AM
