A/C Stuck on Sometimes
Old Dec 15, 2021 | 08:57 AM
billgyrotech's Avatar
Default A/C Stuck on Sometimes
Hi,
I have a 2011 F150 XLT that when starting the air conditioner comes on. This happens without the A/C switch enabled or the defrost enabled. Sometimes it goes off on it's own. I disable it by enablling the A/C switch and disabling a few times.
Is there a relay possibly that is intermittent? I appreciate any help or advice.
Thanks,
billgyrotech
Old Dec 15, 2021 | 11:09 AM
I don't know about any help or advice, but something to consider.
Once the A/C relay is located, if a meter or test light is connected to the relay activating circuit ,you would see if the relay is being activated by something in the control circuit or if the relay itself is self activating. Depending on what I find there will determine how far back in the circuit I would need to check.
If you don't have the equip or knowledge to pin down just where the problem is originating , you might need to have a shop check it out.
Old Dec 15, 2021 | 11:15 AM
Thanks perhaps it would be helpful to know which relay could be causing it. I can replace the relays for much less than a shop would charge.
Old Dec 15, 2021 | 01:40 PM
In the engine compartment is where the relays are located.
Under the power distribution box (Fuse panel) cover it should tell you which relay is for controlling the A/C. That info is also in your owner's manual.
There are usually 2 or more relays with the same part # in that panel, you might try switching 2 and see what changes , if anything.
Old Dec 15, 2021 | 04:01 PM
Thank you very much"hanky" I will give it a shot. Very good advice.
fics
Sep 7, 2019 09:23 PM
2013 galaxie gal
Jul 14, 2016 11:58 AM
Ford2015
Apr 18, 2015 08:12 PM
Richgart
May 10, 2007 01:51 PM
cat
Mar 4, 2006 04:16 AM
