Fuel issues causing slow crank
Old Aug 18, 2023 | 09:56 AM
F250460's Avatar
Default Fuel issues causing slow crank
Hello I need some help having some problems with the fuel system. If the fuel injectors are plugged in and the fuel rail has fuel the truck turns over almost like it's getting hung up on something. If you unplug the fuel injectors and let pressure out of the fuel rail it will roll over fine no issues. Any ideas on what it could be? I haven't gotten a fuel pressure reading yet I will be doing that later bit nobody seems to know in my area what is going on.
Old Aug 18, 2023 | 12:17 PM
Briefly,,, from what you describe,,,,,,,,,,,,,,,,sounds like the injector(s) are not closing.
Did anyone do any work on the fuel system ? Electrical or physical ?
Old Aug 18, 2023 | 12:49 PM
F250460's Avatar
No work was done with fuel system I replaced computer cause my old one was burnt got all the right numbers and calibration code. The injectors are not putting fuel into cylinders pulled spark plugs to check.
dhsvcs
Apr 26, 2023 01:19 PM
Landmann
Feb 18, 2022 07:26 PM
saemetric
Jul 23, 2015 01:41 PM
Stapuph
Sep 23, 2010 09:13 AM
grumpydave
Jan 18, 2008 03:15 PM
