I need help please
Old Jul 21, 2011 | 09:52 AM
tinab110's Avatar
Question I need help please
I have a 2001 Explorer Sport. My oil gauge needle jumps when the gas pedal is not engaged. Is there a problem with the pump? relay? Is this something I could fix myself?
Old Jul 22, 2011 | 08:19 PM
way2old's Avatar
It is possible the wire connecting to the sending unit is not fitting tight enough. Or possibly a bad oil sending unit. I would try that first. Fairly cheap or free fix if it is just a connection problem.
Old Jul 24, 2011 | 03:03 PM
greasemark's Avatar
These had alot of problems with the oil press. senders; they're on the left side of eng, under the power steering, and a bit of a pain to get to, but it's a very common problem. If it's high milage, you might want to stick an oil gauge in there and make sure everything is ok before you put a new sender in.
LakelandF150
Mar 25, 2012 08:57 PM
llazarus10
Mar 7, 2011 05:33 PM
Adhd
Feb 3, 2008 09:55 PM
davequest
Sep 12, 2006 04:16 AM
