2000 ford windstar od light with a p0741 scanner code
Old 07-16-2018, 05:34 PM
jvganzo's Avatar
Default 2000 ford windstar od light with a p0741 scanner code
I've changed the tcc solenoid, trasmission wire harness, speed sensor and neutral switch. Can't seem to nail the problem the od light starts to blink after about 45mph and resets after shutting off the motor any suggestion is highly appreciated.
Old 07-17-2018, 06:18 PM
Are you still getting the same code or a different one?
Or , are you unable to get any code?
Old 07-17-2018, 06:32 PM
jvganzo's Avatar
No, still getting p0741 code even after deleting it. The code came back after a 2 mile run on the highway.
Old 07-17-2018, 06:50 PM
I believe your trans has an input shaft speed sensor and output shaft speed sensor. The input speed sensor may be giving intermittent info to the ECM in relation to the Engine RPM and the system may be picking up the intermittent signals and showing it as a converter clutch problem.
Durfey21
03-13-2020 02:01 PM
Franklin Cognito
05-04-2012 10:47 AM
915exp ford
09-19-2009 01:31 PM
MWalker
04-16-2008 11:59 AM
dlear
02-19-2006 08:46 PM
Quick Reply: 2000 ford windstar od light with a p0741 scanner code
