2007 Ford Escape Fuel Tank Pressure Sensor
Old Mar 26, 2023 | 03:43 PM
KYBRONCO's Avatar
Default 2007 Ford Escape Fuel Tank Pressure Sensor
My daughter had a 2007 ford escape. Check engine light is on and she was told it was the fuel tank pressure sensor. So I opened the tank access under the rear drivers seat..... But the part seems to be like heat srunk together. Any thoughts or helpful tips on how to change this would be greatly appreciated! Thanks in advance.
Old Mar 27, 2023 | 04:51 AM
raski's Avatar
You could test or try a new gas cap. Exactly what code is being set?
Otherwise, take it to a qualified shop for diagnosis if you do not feel comfortable working with it.
Old Mar 28, 2023 | 04:48 AM
When you get burned enough times relying on someone else's diagnosis you learn to go by what you find.
In order to do that we need to know what code(s) were found.
You might be in over your head without a capable scan tool to do a complete diagnosis.
There are some special tools you most likely don't have to effect a decent replacement , if that is really necessary.
katman96
Nov 14, 2022 08:58 AM
James Bobbitt
Feb 11, 2019 11:43 AM
Triaxis
Jul 25, 2014 07:08 PM
donnie beasley
Dec 12, 2011 03:14 PM
BVPE
Sep 13, 2009 02:16 PM
