Drl's 2014 escape
Old Feb 15, 2020 | 03:55 PM
Clay1972's Avatar
Default Drl's 2014 escape
I have a Canadian built escape 2014 base model and I want to turn the drl's off. Was at drive-in and it started to rain. I needed to have the car running and the drl's off. I don't have the setting in my menu to turn them off, and the e-break on didn't work either. Any idea's?
Old Feb 15, 2020 | 09:18 PM
Welcome to the site..
Wanting them off continuous? Or more of a switchable ON/OFF action?
If so, meaning continuous, you should be able to enable/disable them with FORScan and a ‘switchable’ (HS/MS CAN) ELM327 adapter.
Old Feb 15, 2020 | 09:59 PM
Clay1972's Avatar
Thank you for responding, not off while driving, but the ability to turn off while parked. My old cars all turned off with a pull of the e-break.
Old Feb 16, 2020 | 03:20 PM
DRL is a safety feature and disabling or altering possibly not legal or wise. I'm thinking the need is for 'off road' application?? Now
Being its a Canada build, for DRL's it may not be possible to change programmable/mode values within the module, or by hardware.
But,, you could add in a couple SSR's (low current draw solid state relays) just below the BCM (body control module) that triggers by switch, or another power distribution function like the HL switch, door locks switch etc. That would cancel low beam functions when 'input power' to the relays is removed..
So, in short, the Low/DRLs are now cycled 'off' when power distribution is interrupted at the installed SSR's, and DRL lighting goes out because the now open 'relay contacts' have removed power out to the H/L's that came from the BCM but stopped by SSR's..
DRL control is accomplished by 2 non serviceable micro predecessors within the BCM.. To do some circuit changes for cancellation would be at the harness connector wires close to but leaving the BCM (not out by the H/L's, but could be done there) with 2 splices for the relays, a wire run as the trigger source for the relays like HL switch, and 1 ground for both relays..
Wouldn't be a overly difficult if you have basic wiring skills. I could provide you with schematics, connector views, component locations etc.if you wanted to tackle the task..
It's possible that the feature is manageable within the module, but I'd think its mandatory in Canada for DRL as we've seen, and module control alterations locked..
Old Feb 16, 2020 | 04:41 PM
Hey Guys,
Those days when I went to a drive in movie and it rained, I really didn't care if I couldn't watch the movie through the rain drops.and the sound of the falling rain.
Old Feb 16, 2020 | 07:13 PM
Hey Guys,
Drive in movie?! You must be an old guy
econowrecked
Jan 25, 2020 12:05 PM
CCYe350mobile
Sep 2, 2017 05:07 PM
Sub-moa
Apr 24, 2017 01:12 PM
2013FF
Nov 18, 2013 12:35 PM
demonking75
Nov 17, 2008 09:58 PM
