cranks but no start
Old Oct 18, 2018 | 06:54 PM
Joe1965's Avatar
Default cranks but no start
I have a 2003 F150 with a 4.6 could a cooling temperature sensor stop it from running like I said it cranks but wont start
Old Oct 19, 2018 | 09:44 AM
Have verified spark, fuel is present etc?
Do you hear a pump run?
Will it fire on a short shot of ether?
Old Oct 19, 2018 | 04:51 PM
Joe1965's Avatar
I can't hear the fuel pump come on but I have fuel at the rail I don't know how many psi it is though
Old Oct 19, 2018 | 06:43 PM
But is there spark?
Fuel at the rail is good, but doesn’t mean there’s any PCM controlled injector drop/spray..
If it fires on a spot of ether into the intake, ignition related issues can be ruled out,..
Pump run rules out inertia issues, and rail pressure volume supports pump run...
If you can prove out ignition, over fuel delivery, helps in a direction to go.....
Old Oct 19, 2018 | 07:13 PM
Joe1965's Avatar
Well it's not getting fire that's for sure because I pulled the plug wire off for the spark plug in it rounded it to the black Ranger over no spark but I was told that a bad coolant temperature system would cause no spark and I was having trouble with the truck running hot at a stop as long as I was driving it was cool so I have no idea
Paul Kennelly
Feb 11, 2019 12:42 PM
Crownroyal09
Oct 30, 2018 08:12 AM
Jordan Anderson
Jun 9, 2018 12:32 AM
coolbird97
Oct 10, 2016 03:22 AM
19hec68
Sep 23, 2009 11:53 AM
