FORscan and 2000 F-150 5.4 2v Diagnosing Assistance Please
Old Nov 21, 2023 | 04:43 PM
cougar190's Avatar
Default FORscan and 2000 F-150 5.4 2v Diagnosing Assistance Please
As the title says. I have FORscan, laptop and connector. Along with a 2000 F-150 5.4ltr 2v 4x4 truck. The truck is a recent purchase for with no knowledge of it's history. P.O. not mechanical and basically just drove it. When I bought it they had bought a set (8) of coils. FORscan told me it had a miss on cyls. #6 and #8. They had replaced those 2 coils with no change. I replaced those sparks plugs the #8 miss went away (#6 miss was still there). I replaced #6 fuel injector which caused no change. Can someone help me use the the FORsacn to find my problem without having to start getting mechanical ? From my experience (I'm 62 and have been mechanical since 13) it doesn't show any of the typical lack of compression signs, popping out the exhaust or intake leading to a valve diagnosis, no smoking out the exhaust, out the exhaust or excessive blow by in the crankcase either. Motor sounds as if there are no mechanical problems.
Thanks, Ray
Any assistance would be Appreciated !
P.S. I work 3rd shift and sleep a lot so I'm not online much, so please bare with me.
Thanks!
Old Nov 21, 2023 | 07:05 PM
If the misfire is constant , it should be easier to pin down.
Many times the contacts on the coil plug connectors get spread and don't make good contact.
Can you look that over closely and at least eliminate that as a possibility ?
Old Nov 24, 2023 | 11:37 AM
cougar190's Avatar
Although it's kind of difficult with 3>4" of silicone/rubber hanging off the end (like trying to push a wet noodle) they seem to be tight. And since #'s 6 & 8 are new coils, one would think they aren't spread.
Old Nov 24, 2023 | 01:08 PM
We aren't talking about the pins on the coils,but the pins inside the plugs that plug onto the coil.
cougar190
Nov 21, 2023 04:04 PM
Shadetree1
Jul 20, 2022 11:51 AM
Casey Charles
Sep 19, 2019 06:33 PM
juan_v13
Aug 7, 2018 03:35 AM
gashogf250
Aug 5, 2009 05:37 PM
